Jack White:
Hi Matthew,
Wouldn't consider myself a hi fi buff, but since you always kindly take the time to post your findings here, I'll give you my thoughts. Since you're considering budget kit, why not audition some Denon? I own the dcd500ae, which is a pretty good cdp, and I auditioned the pma500ae and 700ae amps. I know whf is not crazy about those, but I felt they held up well against budget HK, CA and Marantz. Added bonus is a (supposedly, I haven't tried that) decent phono stage. Bought my cdp ex-demo, and the amps should be available with a discount, with the 510, 710 etc series coming in.
Hope you find what you're looking for.
Thanks for the suggestion Jack. I think my dealer stocks the Denon stuff so I'll try to hear it as another option.
BTW, you are probably better not being a hi-fi buff and concentrating on the music instead. Its a position I'll be happy to reach to be honest! It can take over a bit.
Thanks again for taking the time to reply.
Hi Matthew,
