Arcam SA30 Questions...
inbox4
32
I'm considering an SA30 having owned an A39 in the past but I'm concerned about all the problems I've read about. I'd be grateful if anyone can answer a few questions:
1) Does anyone know how the SA30 compares to the A39?
2) Does anyone use the SA30 with Audirvana over UPnP? If so, is this problem free and reliable?
3) How do you connect the SA30 to your WiFi network for UPnP? Is this via the Google Home app, the instructions suggest this is for use with Chromecast but I can't see or think of other ways?
4) If Audirvana via WiFi/ UPnP has issues, would connecting a Node 2i via coax or optical be totally problem free?
ASK THE COMMUNITY
