Arcam rDAC trouble with crackling in the right chanel
songox
9
so after a few days of running in my new dac i noticed some very small crackling noise in the right chanel but it would be best noticed when a tune is fadeing out at the end or at the start when its building up so when listening normaly its hardly noticable! so after changeing some cables and diferent sources i got no where and it all leads to the unit itself! question, does anyone else had any problems like that and is there a solution to fix this or should i get my unit replaced as faulty! thanks in advance!
Have you been able to try it with a different amp? The problem could be downstream of the DAC. If you are certain it's the DAC just take it back and ask for a replacement.
no i didnt have a chance to try it with a different amp! im using it with onkyo 608 i think even what hi fi recomended using it with this reciever in one of their issues i suppose they would have mentioned something if it wouldnt be compatable!
Definitely worth trying a different amplifier and or speakers. Also worth double checking the cables.
Alternatively try a different DAC. If this eliminates the problem and you have no more crackling noises then the rDAC must be at fault.
I dont suppose you have a router near your rdac by any chance.
i only ask this as i had same problem with right channel interference with my cambridge audio ipod dac dock i had my router next to it and i noticed this crackling sound in the right speaker,i thought the dac had a problem and was just about to take it back to the shop when i decided to have a move around with my equipment when i noticed that when i moved the router near the ipod dock that the interference got worse so i moved it to the other end of the rack and hay presto no more interference, few no worries about having to travel 15 miles to the shop and getting the i pod dock replaced.
anyway no more waffling just a thought.
regards 80s boy
just had my dac connected to my friends home cinema set up and the problem is still there! unless anyone knows if i connected it to my laptop via usb would there may be some software update?
I think you've gone to enough torture.....bring it back for a replacement....or at the very least, phone Arcam. They are most helpful.
This may seem obvious, have you tried swapping the left and right channel cables on the output of the rDAC.
If the noise now appears in the lef t channel - the right channel of the DAC is the problem.
thanks everybody for the help nothing seems to help so i will have to contact the seller and see what the options are! thanks again!
