Arcam or onkyo
Looks like I'm in the market for a change of amplifier. So the ones I'm looking at are Arcam alpha 8 pre and power amp combination. Which I would hope would give me a warm smooth sound or a onkyo a 9050. Looks like it's going to be a 5 star amp and I do have the tx8050 and the onkyo c7070 so I do like the onkyo sound. So to very different amplifier s.what do you think? Any other amps you would consider pros. And cons
i have just read the onkyo review in whf lean sound so thats out.so maybe a rega brio r.they seem to have a warm sound anyone on here use one as there main amp?
The TX-8050, according to some owners, betters a lot of sub-£1000 integrated amps. Whether that's true or not I couldn't say, but I think, if sound quality is the goal, you'll need to stretch your budget a lot further: Look at Creek Evo2 or other amp of similar quality.
T
the record spot
Yip, and I'd be one of them. Delivers a massive amount in a small package. I'd take it over the new budget Onkyo range too. 100wpc, four digital inputs, Spotify onboard, can take a power amp and a subwoofer, quite a neutral sound, so it's straight down to your speakers and CD player or whatever. Fabulous for the money.
Shanka
123
I bought a s/hand alpha 9 last year and love the sound of it, feels warm, not laid back, can listen to it for hours and often do as I have it in a room with my computer.It has plenty of power and produces plenty of air in the sound and is certainly not bright or harsh as the B&W speakers I use with have a slightly bright top end so in my opinion they work well together.
I have not heard the Alpha 8/power combo but if it is much the same as the 9 I would be happy, the amp only cost me £130 w/o phono stage.
I personally find Creek amps a little to laid back and 'dry' sounding but that is only my view,
Good luck with your choice, do try and hear first of course.
csq2
24
I actually just upgraded to the Onkyo A-9070 from a Rega Brio 3. The bass on the Onkyo is amazing: tight, controlled, and extremely detailed. Vocals are very clean and have a degree of warmth, unlike the A-9050. Actually it has the eloquent sound of my Rega, but with better bass and extended highs. I was surprised by how similar it sounded compared to my Rega Brio 3, but everything sounded tighter and more defined with the A-9070. The A-9050 is excellent for the money, but there is no info display which is a shame and the onboard dac is of inferior quality. Rotel RA-10 is also excellent for the money, but it really needs a remote.
Here's my list of recommended amps:
1. Nuforce DDA-100
2. Pioneer A-70
3. Vincent SV-400
