Thanks for update.Thanks for the extra thoughts. Quick clarification on my situation...
The CDP is actually a CD72T. I assume that shouldn’t make too much difference to the running temps, although I know there’s a bit more kit squeezed in there compared with the CD72.
Also, my hifi is inside an almost entirely enclosed Ikea AV unit, with almost no clearance above the CDP to a glass shelf. I have left a larger gap above the amplifier and I run the hifi with the glass door open about 2 centimetres at its widest point (this is a concession to my partner who isn’t that keen on seeing my hifi!). I tested my current Arcam 7SE inside the unit and noticed that it runs a bit warmer in there, and the CD72T is nice and cool when it is running outside of the AV unit.
I am already planning to install some quiet 120mm pc cooling fans to aid ventilation, I’m just waiting on a fan controller unit to become back in stock next week.
Thanks - yes I have never run hifi inside a unit before, but needs must until I can afford to move to a larger home again. I will be running up to 3 fans all set to extract heat to the rear of the unit, drawing cooler air in from the front. Does that sounds ok?Thanks for update.
That may explain things.
Personally I wouldn't run anything inside an enclosed rack, with my power amp I couldn't it would melt.......
Overheating will kill your kit very rapidly.
Re arrange shelving or fit fans but don't forget that that heat has to be extracted not blown back an itself.
I guess you'll soon find out.......Thanks - yes I have never run hifi inside a unit before, but needs must until I can afford to move to a larger home again. I will be running up to 3 fans all set to extract heat to the rear of the unit, drawing cooler air in from the front. Does that sounds ok?
Yes I will provide an update. Thank you.I guess you'll soon find out.......
Let us know how it goes.
You're not alone in making concessions to your partner Tomcat. I've read descriptions of people's 'better' halves dictating just about every aspect of their hobby.Also, my hifi is inside an almost entirely enclosed Ikea AV unit, with almost no clearance above the CDP to a glass shelf. I have left a larger gap above the amplifier and I run the hifi with the glass door open about 2 centimetres at its widest point (this is a concession to my partner who isn’t that keen on seeing my hifi!)
😆 indeed!!! The hinges sound pretty ingenious- where did you source those? My partner is pretty reasonable, but doesn’t like seeing cables which makes separates hifi a tad challenging!You're not alone in making concessions to your partner Tomcat. I've read descriptions of people's 'better' halves dictating just about every aspect of their hobby.
(Including one bundle of joy that 'didn't like music' and wanted her partner to sell his hi-fi!!! FFS.)
Every time I read these things, I'm so grateful I live alone.
My equipment is also in an Ikea unit with doors. I bought some (expensive) Parliament hinges which allow the doors to fold back 270 degrees to each side.
Your fans may be quiet, but they won't be silent....hope your partner will be OK with the noise .
"Well at least you didn't have to put up with the fan noise dear......shame the house is a pile of ashes".
Quite so, should have seen the set-up I had prior to marriage.You're not alone in making concessions to your partner Tomcat. I've read descriptions of people's 'better' halves dictating just about every aspect of their hobby.
It really wouldn't have helped, the ambient temperature was certainly concerning me.I don’t think the recent warm weather is helping either (no air con in our house).
You might have a dodgy Q Box, mine runs warm if anything but then again, like all my gear, it's in an open rack.Here is an update on the situation as promised ..
I have installed 3 x 120 mm Arctic PC cooling fans at the rear of the AV unit. They are set up to extract hot air out of the unit, with the door being kept open about 2 centimetres to allow cool air in. The fans are powered by a Phanteks fan controller which has a 3 speed, wired remote control.
This has helped significantly, with the outside cases of the CD player and amp being cool to the touch now 🙂.
I located the fans at the same height or slightly higher than the top unit on each shelf (which were the CDP and Amp).
As an aside, the Sky Q box which is notorious for running hot, still runs very hot (which is placed on the very top shelf with its own extracting fan too). I think Sky must source their components from Breville?!!
