Vladimir said:TBH I don't see the point changing the Arcam Solo. MA RS6 are 91db (1m/1W).
plastic penguin said:@insider9
There's a flaw in your reasoning: You are comparing MA RX2 and an early Primare (one JD had for many years), and one he partnered with a number of speakers - PMC DBs and AVI passive standmounts are two that spring to mind. IIRC, and I'm going back to 2008 on this forum.
The RX range bears no resemblence to the older RS ranges. I will always love the RS6 but they do need careful partnering. On the flipside --I've heard the RX6, 2 and 1s -- the RX are more amp freindly.
insider9 said:Fair enough. I can only compare the components I've heard. I've been through quite a few speakers in the last year. Also had the small RS floorstanders, RS-5. I've not had either of them for long to be fair but gave a fair listen to both over a couple of weeks. They're decent speakers but I've not been smitten with either to be fair. As to overall difference from MA speakers I've owned and heard (B2, Bronze 2, BX-5, Silver 2, RX-2, RS-5, old gold floorstanders) I admit I preferred the older lines. As to difference RS-RX I don't think they're as far apart.
I appreciate that I don't compare like for like and that's a fair comment. I also appreciate that you have more experience so no problem there. If OP doesn't see my input useful that's fair enough. It's ultimately his decision 🙂
plastic penguin said:@vlad
"TBH I don't see the point changing the Arcam Solo. MA RS6 are 91db (1m/1W). "
That seems logical. However, if you have a fairly low-powered, budget amp it can struggle (if cranked up) with the RS6s 6 ohms. That was the issue I had with the Arcam A65. No issues at low to medium but once the volume started to creep above 11 o'clock, in certain frequencies, clipping could be heard.
I take it you mean... Most POORLY designed amps do that.gasolin said:plastic penguin said:@vlad
Lol most amps play loud at 9 o'clock max at around 10 o'clock and distort at 11 o'clock
https://youtu.be/JhuWuTDZiuI?t=20m38s
Bi amping with Solo and P75? Definitely not.TheMaestro said:Thanks for all the input guys.
Would adding a Arcam P75+ bi-amping mean an upgrade for my Arcam Solo?
Plus oneinsider9 said:I take it you mean... Most POORLY designed amps do that.gasolin said:plastic penguin said:@vlad
