Arcam A19 and Project Debut III SE - problem pairing
abakar
Hey all, apologies for being a complete newb here. I've had the Arcam A19 for a while and recently took the plunge to get a turntable. For some reason it just sounds really quiet. Otherwise using different sound sources it sounds great. Connected it to the phono output but still no good. Any thoughts on what the issue might be?
Thanks a lot in advance
What volume settings do you find yourself using for your various sources?
How does your record player sound if you simply turn up the volume control to match the level of the other sources?
abakar
This should help:
Line-level phono input
The phono input may be changed from phono-level to line-level. Press the front panel PHONO and BALANCE buttons simultaneously and use the control knob to change the setting. The front panel display shows LINE- OFF (i.e. phono) or LINE- ON respectively.
If you wish to use an external phono amplifier, connect its output to the PHONO (MM) input, but make sure that LINE- ON is selected, since a phono amplifier produces line-level input.
Regards
True that many of these entry-level carts (Ortofon in particular) have a fairly low MVs. That's the only criticism I have of the ClearAudio.
