Anyone heard the new Line Magnetic DAC? It's, I think, a Korean company based in China. No reviews on the interweb that I can find. I can get it for about 500 British pounds where I live. It would replace my Asus Sonar Essence ST, to be fed into a Rega Brio-R, to Monitor Audio Silver RX1. Listening mostly to 24/96 vinyl rips of jazz, acoustic, rock, and FLACs for everything else (More from The Field pls!)
The other contender is the Peachtree DAC iT, which is a bit cheaper but not available in my city. Am planning to replace within 12 months the MA with PMC Twenty 21s, as small room dictates the speakers are up against the wall, so I like the forward firing port. Due to LM's rep, I am guessing this DAC might punch above its price tag and become a permanent fixture in the kit.
Thanks for any help!
:help:
Stats -
LM-502CA digital DAC
receiving and decoding 32bit/192kHz high resolution digital signals.
ESS 9016 DAC chips, five digital inputs: AES/EBU, BNC, USB, OPTICAL, and COXIAL.
asynchronous
separate power supply for Analogue and Digital part: Toroid power transformer for Digital part while EI power transformer for Analogue part.
Digital circuit has taken high speed rectification circuitry while Analogue parts has taken 6Z4 for tube rectification.
Two pieces of 12AU7 are employed at Tube buffer plus solid state output stage:
Frequency Response: 15Hz~50kHz
Sampling Rate: 32bit 44.1KHz 48KHz 88.2KHz 96KHz 176.4KHz 192KHz
Digital Input Impedance: 75Ω
Output Impedance: 2kΩ (Tube), 600Ω (Solid State)
Dynamic Range: 120dB
Size (W×D×H): (376 x 345 x 191.5 )mm
Output Voltage: 3V+-0.5dB (Tube), 2.5V+-0.5dB (Solid State)
THD: 0.5% (Tube), 0.02% (Solid State)
Power Consumption: 24W
:help:
Stats -
asynchronous
