Anyone recognise these speakers
camcroft
669
316
19,270
These pictures are from another forum no one knows what make they are and they don't have any markings on them real wood veneer and decent connectors so most probably a decent european make
Deleted member 116933
Take one of the cones off. They will be labled. With date of manufacture and who they where supplied to
camcroft
669
316
19,270
The op on the other forum did that at my request the tweeter and the woofer are both Seas so again as I said I doubt that they are cheap and nasty make.
camcroft
669
316
19,270
Connectors too recessed for comfortable spade or bare wire.
They've got a bit of a (well made) home made look to them.
Might be some clue inside.
As I said these are not my speakers this is on another forum and everyone is curios as to what they are and the connectors would be fine with Banana plugs so again not cheap and nasty in design
I doubt they are I have googled it and got images and having owned Heybrooks in the past they always had a name or plate somewhere on them with the model no and Ohm rating
Yes, coming from Plymouth I have had plenty of Heybrooks. The original two's didn't have anything on the front although may be a prototype as the two's had different tweeters to yours and, come to think of it were rear ported. The HB2R had Velcro attached grilles.
Any chance they are simply a home build?
Gray
I'm certainly not saying they're a cheap and nasty design.
Not especially decent, just standard non gold-plated 4mm binding posts aren't they?
They're certainly adequate and of course banana plugs fit into them (y)
Maybe they are a prototype that some employee got hold of.
ASK THE COMMUNITY
