Anyone own tx-p55vt30?
hi
doe anyone here own a panasonic tx-p55vt30 i just bought one last wednesday ,the picture is excellent, but there is a irrating buzzing noise coming from the back, like a cricket or mosquito noise i can here it from 4metres away when the volume is set low.
Has anyone else experienced this?
how can i fix this?
Oldboy
421
Hi there,
My 2nd TX-P42GT30 had this exact problem. You have to expect some level of buzzing from a plasma tv just because of how they work but when i rang Panasonic UK about my buzzing issue i was told that if the buzzing is audible when the tv is at 1/3rd volume through the tv speakers it may be indicitive of a problem.
My GT30 still had the buzzing at that volume level so i took it back for a replacement and Richer Sounds exchanged it with no worries, they told me it is normally down to power supply issues. If your VT30 has buzzing at 1/3rd volume then i would want a replacement so contact your retailer and/or Panasonic depending on how long ago you purchased it.
