Anyone heard the Monitor Audio BR1 speakers
Yes, that was the combination I used to use...
And very nice sounding too 🙂
Fully agree; theyre great little speakers.
Have you demo'd the B&W 686's at all?
You could also consider the B&W 601 S3's; theyre very good little speakers and front ported as well so are fine with being wall mounted
Chebby what did you think the systems main short falls were - this is only for a kitchen system so volume is not an issue as have a big system in my lounge
Well then yours will be even better because the Carbon 2 provides 25 watts per channel whereas mine only gave 15.
Given the 91db sensitivity of the BR1's, then that combo should not run out of steam even in a reasonably sized living room, let alone a kitchen.
Discussions are always the main source of accurate information and to ensure a comfortable results, you can get immediate and reliable information, which will definitely help you in every area of your concern.
I have the MA BR1s with my DM37. Think they are lovely little speakers. Funnily enough I don't think they've ever been reviewed in WHF. I put them up against MS902i, Wharfedale 9.0 and Tannoy F1s before making my decision to buy. And I have them wall mounted.
Rich
Edit. Just noticed how old this thread is. Should have looked before I posted. I imagine OP has already sorted it!
reggaedave:cheap as chips thesedays aswell....
Not too sure about that reggaedave. Just looked at 3 sites and cheapest I found was £159 a pair. Thats about 40 quid more than I paid for mine 18 months ago. I was quite surprised.
Rich
ma br1's are a great little speaker use them at them at the front of my home cinema sound solid with mtv.
