Monitor Audio Gold 50 6G speakers
I currently own the Monitor Audio Gold 50 6G, having previously used the Silver 50 7G. Although I wouldn’t call myself an audiophile, the differences between the two were immediately noticeable.
Listening to Diana Krall’s “I’ve Got You Under My Skin”, the Silver 50 created the impression of a large, virtual face projected between the speakers. By contrast, the Gold 50 suggested a smaller yet more sharply defined presence. With strings, the Silver 50 felt tightly wound, while the Gold 50 carried a more relaxed character. In the bass, the Silver 50 produced strong, forceful notes, whereas the Gold 50 pressed forward with steady, unwearied momentum.
Another test track was Krall’s “The Girl in the Other Room”, chosen because cymbals and hi-hats are notoriously difficult for speakers to reproduce. On the Silver 50, cymbals sounded natural; on the Gold 50, they gained a rhythmic quality—smooth yet distinctly musical.
The Silver 50 already gave the sense that sound was escaping the cabinet rather than being confined within it. The Gold 50 took that freedom even further, producing a presentation that felt more natural, lively, and effortless, yet never harsh to the ears.
In short, the Gold 50 seems — if I may exaggerate a little — to convey not just sound but emotion. Even at low volume, the audience’s applause comes across as open and expansive. It leaves me with the impression that this might be the path toward true high‑end sound.
Thank you so much for the reply,they seem amazing speakers!!!Like you i do not call myself audiophile ,this will be my first hifi speakers (20 years i use studio monitors). May i ask you something else do you think that will be ok for nearfield 1,5 meter listening (aprox 4,9 feet)? And i suppose from the things you said its not fatigue after some hours listening?
My music listening room has a volume of 29.61 cubic meters (420 x 300 x 235 cm). The distance between the left and right speakers is about 180 cm, and I usually listen to music from a distance of 120–220 cm. I believe that at the 1.5‑meter listening distance you mentioned, the sound quality will be more than sufficient.
For reference, I am a low‑volume listener who enjoys music at 45–65 dB, and I also use a subwoofer with a lower frequency limit of 37 Hz.
I hope you gather enough information to make a satisfying purchase. If you have any further questions, please feel free to let me know anytime.
Reactions: Harris ARP
My music listening room has a volume of 29.61 cubic meters (420 x 300 x 235 cm). The distance between the left and right speakers is about 180 cm, and I usually listen to music from a distance of 120–200 cm. I believe that at the 1.5‑meter listening distance you mentioned, the sound quality will be more than sufficient.
Thank you so much,i really appreciate all your help!!!
That's a very insightful description of their sound characteristics (not that I have them, but you give a good idea of how they are an improvement on what you had before). Very good small bookshelf speakers are quite hard to find imo, I have tried several of the models discussed here and all of them came up short when compared to my Triangle Esprit Titus. Would be interesting to hear these.
No, I've demoed the Gold 100 5G and they were good. But when I directly compared them to the Amphion Argon 1 and Dali Rubicon 2, they came up short sound quality wise.
It'll depend on what amp you are proposing to use with them. As @Messiah and @Al ears have suggested a demo is the only way to know is whether they tug your rug or not.
Hi!!!Which one did you like the most Amphion or Dali ?
Thanks AI, I can't look at the link while using my work laptop (blocked on eBay but not Amazon, how weird).
Thanks I'll look at it later 🙂
Checked on my mobile 😊
Really nice... But still crazy money!
Thanks.
I promise missus to first upgrade the windows and door in the conservatory, that's going to set me back, more than the costs of the speakers.
Hopefully, when house duties are done, I can look at it again.
A have a new radiator to fit in the bathroom next week, ages since I last did the plumbing. Should be fun 😊
Thanks.
Enjoy!
Sounds like by the time you can afford to buy them they will be £20 on eBay.
