Hi George ,
You gotta love this site , I wrote you a reply and its gone , so I'll try again , keeping it a bit shorter this time <S>
I've had mine for nearly two years and the best way to describe it is effortless , natural and enyjoyable soundstage and imaging is excellent from singer songer writers to sloppy rock n rollers it never falls apart , detail in spades , total control over my 4 ohm Dalis .
But , it's a digital amp if you add the analogue module , at 300 quid, it's also an A to D card , wilro15 , from my faulty memory, said it wasn't "dirty enough" with his TT. You can plug a mac/pc in the back and it will play itunes files , a windows formatted HDD with flac files can also plug in the back and be controlled by the R/C , it wont play ACC from the HDD.
I think you really need to home demo one because you will have to use a digital out from your CDP will will in effect be replacing both your CDP and AMP in one go
James
