Any suggestions to narrow search down for new standmount speakers
nfshirley
Hi All
I have some budget to get a new set of hifi speakers. I have around £600-£700, but could push the budget a little more if what I was buying was really worth it.
My setup is a Marantz CD CD6002 (I will be changing this next year) and a Cyrus 6XP amp. I have some Atacama stands and I would like to add some speakers to the setup.
I listen to folk, female vocalists, indie, pop and a small amount of classical music. So quite varied. I like a detailed and clear sound ideally with a hint of warmth (not too much).
I have a medium list of the below speakers and I'm looking for to try and short list it down to two or three sets that I can listen to before buying.
Totem Dreamcatchers, Spendor S3, Ebacoustic EB2 (I appreciate you can't listen to these before you buy), ATC SM11 (a little pricey), Dynaudio DM /6 and finally Tannoy Revolution Signature DC4.
Any opinions, advice, thoughts most welcome.
Neil
nfshirley said:
Hi All
Neil
Hi Neil
Although over your budget ATCSCM11 monitors are worth every penny of their asking price and then some 🙂 In addition to Dynaudio's excellent DM 2/6 and DM 2/7 models their Excite X12's and Monitor Audio's new GX50's are also worth a look 8)
All the best
Rick @ Musicraft
nfshirley said:
Hi All
Neil
Yup, Dyns are traditionally a very good match with Cyrus. Worthwhile checking out PMC DB1is. Cost is around the same price as ATCs but far easier to drive. I also think Totem maybe a good match for the Cyrus.
matthewpiano said:
I've heard Spendors sound excellent with Cyrus so would definitely audition those.
I agree and available here: http://www.bartlettshifi.co.uk/product_detail.asp?sku=1307
Also listen to Epos Epic 1 or 2. They have a sweet but very detailed sound(stage) and are not that expensive. If too sweet for you than Epos M5i or M12i, more expensive and brighter!
Good luck!
many thanks to everyone for their suggestions, they are much appreciated and have given me lots to think about (and listen to).
IMO two of the best small bookshelf speakers you can buy are the PMC DB1i and the ProAc Tablette Anniversary.
The latter at 1250 quid however, might be above your budget but I think it's worth every penny.
