Any suggestions for a subwoofer to go with Monitor Audio RX1?
Midisurf
There is no way I can afford the RXW12 and I heard MA subs aren't worth the money. Do I need to be careful when choosing a subwoofer to match these speakers? My budget is £400.
Midisurf
350cm by 288cm. Just a bedroom but was thinking of buying the Monolith and sticking it in the corner would fit perfect near my door.
CnoEvil
556
11
I don't think you need more than the XLS 200, but give BK a ring and talk it over with them.
Good Luck
Cno
CnoEvil
556
11
Midisurf said:
What would happen if I stuck a Monolith in this room?
IMO.It would overpower it, unless very subtley set up (though BK are the best people to ask - very helpful).
I had a 12" sub that had no problem delivering an ample sufficiency of bass in a room that measured 14ft(W) x 22ft(L) x 11ft( H ).
Coll
50
I agree with CNO I have RX1s with a BK XLS200 my room is 7m x 4m x 2.5m and there is plenty of bass, but I use mine for music only. As CNO says I suggest you speak top Tom at BK Elec.
