David@FrankHarvey said:Excellently!
steve_1979 said:Do you have any suggestions for any cheap (possibly secondhand) options that are worth trying?David@FrankHarvey said:Excellently!
David@FrankHarvey said:steve_1979 said:Do you have any suggestions for any cheap (possibly secondhand) options that are worth trying?David@FrankHarvey said:Excellently!
Do you mean in the Antimode one up? Or alternatives?
steve_1979 said:Dunno really, I've never looked into it or heard it before so I'm a complete noob. As far as my ears can tell there aren't any issues with the acoustics in my room so I'm not really sure if it would be worth the hassle.
Just thinking out loud and wondered what other people think of the idea.
bigboss said:steve_1979 said:Dunno really, I've never looked into it or heard it before so I'm a complete noob. As far as my ears can tell there aren't any issues with the acoustics in my room so I'm not really sure if it would be worth the hassle.
Did you check the thread I posted above?
This is my argument to those with AV systems. If it sounds fine, don't mess. Sometimes adding in extra processing can have a negative effect, despite also having a positive effect, if you know what I mean. Having tried it for myself in my own system, I know it will make a positive difference, but it sounds fine as it is.steve_1979 said:1. Is it worth it if there are no obvious problems to start with?
The 8033 Antimodes have a single measurement point. The Dual Core allows more than you'll ever need. Entry level AV receivers are generally a single point measure system, midrange ones are around eight or nine points, and top EQ systems in AV receivers can allow more like thirty or forty or so. A single one is fine for the sweet spot, but not for anywhere else in the room. Multiple measuring points are better to cover more seating positions, but you have to bear in mind that the more measuring points there are, the more the end result is 'averaged out' to suit that wide area.2. How does it effect the sound when you move around the room to different listening positions?
David@FrankHarvey said:This is my argument to those with AV systems. If it sounds fine, don't mess. Sometimes adding in extra processing can have a negative effect, despite also having a positive effect, if you know what I mean. Having tried it for myself in my own system, I know it will make a positive difference, but it sounds fine as it is.steve_1979 said:1. Is it worth it if there are no obvious problems to start with?
The Dual Core is the most flexible in this respect as you can store different profiles, which can be used to cover different areas of the room.
