I bought a TCL android tv it has no record feature at all ( could not beleave this ), can't use a usb stick either. So can anyone tell me, is there any way to record on this tv
says it does.
But does not say rerecording.
- Features USB video playback.
it playback videos store on USB stick from other places, I think thats what that means
@Messiah I don't seem to have any options like that on the scrernLooking at the FAQ’s I found:
You must use a USB key, which must be inserted into the apparatus. This must be in FAT32 format, with enough capacity to enable recording (minimum of 1 GB) and a write speed of 8 Mbps. Count on 16 GB for 1 hour’s worth of recording. Only free channels can be recorded, and viewing these recordings can be done only on this TV due to copyright reasons. To make a PVR recording: Press "Option" on the remote control and select "PVR quick access" (OK). Then, press the red button (at the bottom of the remote control) to start the recording and press the green button to stop the recording manually. If you have opted for automatic recording, use the browsing arrows to adjust the recording time. If the recording time is reached, then the recording will stop automatically.
