Hi all... I have 2 systems. My second system has a Rotel 840 BX4 amp feeding JPW Sonata speakers that is starting to fail. Main system has a Cambridge Azur 651a amp running Triangle Esprit Titus speakers. Sounds good, but wondering if I should keep the Cambridge, and replace the Rotel, or... shift the Cambridge over to replace the Rotel and then get a new primary amp to run the Triangles? Read that the Cambridge could be too bright for the Triangles and that a warmer/smoother amp may give them a lift and enhance my listening pleasures... The Creek evolution, Roksan Kandy, Myryad, Cyrus and Rega Amps have good reviews in this area. What do you reckon, stick with the Cambridge as little step up... or switch to a different amp for the Triangles? I tend to buy second hand by the way...Cheers for any insights and suggestions.
