Hi!
I've recently moved to a new apartment and I'm trying to use it as an excuse to improve my stereo.
I currently have Technics SU-VX500 Amp with Alcomax gamma floorstanders (80/150W, 8ohm), connected to Rega Planar 2 turntable.This has been my first stereo ever and I got it for nothing, so I've never really wondered if it gives me the sound quality I want. I used to listen to it in a much larger room though and now I neither have the space for this gear nor I'm satisfied with its performance.
I'm therefore looking for new gear and I'm thinking of a setup with TT + PreAmp + Amp + Standmount Speakers, as I would ideally like to have the below layout.
Do you have any recommendations on:
1. If placing one speaker on a cabinet and one on a stand of equal height is a bad idea and if so, how bad it is
2. Whether to use Rega Fono A2D Mini as the PreAmp or Dynavox UPR-2.0 instead, to have a headphone output from the PreAmp. I would like to spend <$200 on the PreAmp, new or used and each of these would cost me around $100
3. How you would split your budget between speakers and amp? I intend to spend $800 tops, is it reasonable to to spend equally on speakers and amp?
3. What speakers + amp combo to choose within my budget?. For speakers, I've been thinking about ELAC Debut B5.2, Q Acoustics 3020i or Triangle Borea BR03 from the new ones, but I'm also looking at used Chario Syntar 100 and B&W DM 601 S3. I'm clueless about the amp though. Doesn't need to have a phono stage as I'm gonna have a separate preamp to place the tt far from the speakers, I would also prioritise getting best sound out of the tt over multifunctionality (bluetooth, 50 different inputs etc.)
I listen mostly to jazz and hip-hop, but in general a fairly wide range of genres. Medium loud, not a huge fan of deep bass.
Any advice would be largely appreciated!
