gasolin said:
obiwan kenobi said:
Surprise; it will not be the Wahrfedale. Heard the Q acoustics 3050 and find it a better speaker than the Wharfedale. Also heard the Tannoy xt6f. Horrible and unlistenable bright. Even the MA Silver 6 sounds better! (and warmer).
Is a NAD c356 a good amp for the Q acoustics with rock and metal or better another amp?
I find misson LX better Than Q Acoustics Nad/Marantz is a good amp for Q Acoustics
How different the new nad amps are to the old ones i don't know
To be fair you are comparing one set of budget 3020 and lx2s on poor stands without really trying out positioning. Your experience is very valid, but it wont hold through for every other option in those speaker ranges.
Seems like you're enjoying the missions though, graet stuff
