Hello guys,
Recently bought a pair of Q Aqoustics 3050i and connected them with a cheap Pioneer A-10-K amp. The result is very bad, almost to the point of wanting to give up - sound is dull and shallow, bass is weak and uncontrolled. Source is Spotify from Smart TV, via analog/aux output. Anyway, guess these towers need a much more powerful amp so I narrowed down my choice to Yamaha A-S501 and A-S701. The 501 is within my budget at the moment and I can order it right now. Will it serve its purpose properly? I want a fast and upbeat sounding system which makes you want to rock.
Also thinking about if I should replace the speakers with Monitor Audio Bronze 100's with the intention of having a faster and tighter bass response as they're bookshelves with a big 8inch drivers.
Thanks in advance!
Thanks in advance!
