Amp around 70-80 watts
kukulec
42
8
10,545
Hi, slowly it is time to get an amp where the sound has more "body". I have heard the Cambridge CXA-60 and CXA-80. Contrary to WHF reviews, I strongly preferred the latter. Which other amplifiers are in this league? Do you have any recommendation which one should I listen?
Gazzip
88
Abrahamsen V2.0 could be worth a listen.
drummerman
540
Both Naim and Cyrus have a 'solid' sound. Naim darker, Cyrus more explicit. Marantz sounds more 'rounded' with a softer, warmer bass and less incisive treble but still detailed.
The above changes a little as you move up/down the range but the house sound is there regardless.
There are others and much depends on speakers used.
jonathanRD
175
50
18,670
Maybe it would be better to give details of what dealers you have near to you and what they stock - that's assuming you can audition them and them take them home for a further listen.
It's all very well everyone giving suggestions but ideally you want to listen to them.
From me I would add the Rega Elex-r and Arcam A29.
davedotco
An awful lot depends on what is available to you in your market, which I guess, is not in the uk.
My favourite amplifiers in your price range would be the absolutely 'hair shirt' Croft integrated or the more normally equiped Creek 50A, both just under £800.
Neither are easy to find in the uk, so whether they are available to you, I have no idea. Personally I find them to be a class better than the more mainstream items at comparable prices. I am not a fan of the Arcam A19 but if you can find the A29 within budget, that is definately worth a listen.
The Abrahamsen integrated mentioned above looks fantastic value, but distribution/backup might be an issue, it is available in the uk via Iqspeakers, a chap who posts on here. Again, whether that is a sensible choice for you depends on your market.
kukulec
42
8
10,545
I checked if Abrahamsen, Creek, Rega can be bought here, but I have found nothing. Naim is overpriced in my country.
There is: Vincent Audio SV-500; Advance Acoustic X-i105; Teac AX-501DA; NAD C 368; NuPrime IDA-8; Exposure 2010s2 D; Marantz PM8005; Magnat MA 600; Arcam A29. Unfortunately home listening is not really an option in the hungarian hi-fi culture.
Muddywaterstones
What about Heed? They are a Hungarian company. Their Obelisk iii has a nominally low 50 watts but kicks like a mule; and in a most musical fashion too. It is probably above budget but I don't know in your market. They have another line that is a bit cheaper which I haven't heard called Elixir or something.
davedotco
Off those you list, my preferences would be for the Arcam or the Exposure if they are in budget.
However that does show my 'prejudices' pretty clearly, I make no apologies, these are the kinds of products I have owned and used for many years.
Al ears
Moderator
Not having heard most on that list I can only comment on the ones I have, so agree with above and that's the Exposure
Electro
43
You could try Abrahamsen direct from Norway, they have a mail order service so you can try one .
http://www.store.abrahamsenaudio.no/
avole
17
Abrahamsen might be good, but they're hardly a major player. Stick to brands with a local presence.
muljao
154
Why not the CA80 if you liked it. Plenty power, good inputs and a generally well reviewed unit?
rainsoothe
417
168
19,070
Hi. +1 to the Heed recommendation, if you can fit it in your budget since you're based in Hungary. Maybe even a used or ex-dem one.
Also Arcam, Exposure and Abrahamsen are well worth an audition.
ASK THE COMMUNITY
