Alternatives to Vogel Wall Support (EFW6345 / EFW6325)?
tom_mk
17
I have just purchased a Panasonic TH-37PX80, which is due for delivery tomorrow, and need a way of mounting it. We have a long (5m) thin (3m) living room and the screen will be positioned against a long wall, and therefore viewed across the room, most likely on a diagonal. With this in mind it looks like the Vogel Wall Supports would be the most suitable due to their flexible positioning features.
Before I make the plunge and spend a couple of hundred pounds on a wall bracket (can't believe I just said that) are there any other options that I should consider or have I done my research well. (Also bare in mind that I have an 11 week old daughter who at some point i bound to start crawling, walking and generally making mischief). Another point to bare in mind is that the floor in our lounge isn't perfectly level, so any unit (if suggested) should have adjustable legs.
Thanks for any advice/suggestions.
Tom
I got mine from ebay and it is brilliant (I think I could hang off it). It set me back about 45 quid and it is solid. It's one of those cantilever designs that tilts and comes out and can turn at nearly any angle you want. Try this link for an idea of a similar one to mine
http://cgi.ebay.co.uk/Plasma-LCD-SWIVEL-TILT-WALL-MOUNT-BRACKET-TV-32-42_W0QQitemZ190240389734QQcmdZViewItem?hash=item190240389734&_trksid=p3286.m14.l1318
There should be ones on there in black like my one to go with your telly colour.
