Advice on rear and centre speakers
rick190
Hello my setup is as follows
Dali Zensore 5 floorstander speakers
Denon AVR-X2200W
SVS PB2000 Subwoofer
I am looking to upgrade to surround sound and want some advice on what centre and rear speakers would be best for this setup?
Ideally I don't want to spend more than £300 for the centre and rear speakers together.
Benedict_Arnold
661
Don't believe the hype that the rears have to be the same brand and range as the fronts.
Centre, probably. Foor best results? Certainly.
But the rears? Not so much. They're only producing surround sound effects, after all. If cash is tight and you can't afford the Dali rears right now, try a pair of cheap bookshelf speakers off eBay and see how you get on. If they work well enough, great. If not, flog 'em on for more or less what you paid for 'em when you've got the cash to upgrade to the Dalis.
