Advice needed on Panasonic L37G10 please
I'm looking to buy the new Panasonic L37G10, but am a bit concerned as a couple of reviews state the tv doesn't handle SD footage very well. I know people have different views on how things look but I don't want to spend that amount and find the SD channels are unbearable to watch.
Also, I didn't know if the tv was tested with an SD analogue signal or not as I've got a Sky HD box so would hope the SD channels would be better quality.
Has anyone seen one in action and do they have any opinions?
Stuart
Go and see one at a proper retailer. Forget buying based on the opinions of others over the internet. Put your business the way of a proper dealer who can demonstrate the performance of the set and provide comparisons with equivalent models. As a bonus you'll get more support if anything goes wrong later on.
Thanks for that. Unfortunately, there aren't that many on display at the moment but I will get phone bashing
If anyone else has any ideas then all help is well received
