42 inch and 40 inch TV Much Difference?
  • Thread starter Thread starter Deleted member 2457
  • Start date Start date
Deleted member 2457
Hi
I would like a 42inch or a 40inch tv in the future, it has to be 1080p.
I was wandering is there much difference between the two for blu ray.
I know you recommend the bigger the better.
Any thoughts would be great.
Andrew Everard:So small a screen size differential wouldn't be significant.
Okay thanks.
Here's another question where do you see TV's going in the future.
By which I mean they are getting thinner and lighter by the year.
Would it be possible to say get a 50 inch one weighing in aroud 22.5kg in the future and being really thin?
and if yes how long into the future are we talking? Because currently that's seems to be the weight for a 40inch.
I see no reason why such a combination of specifications shouldn't be possible at some indeterminate pont in the future - after all, there are already 46-47in TVs weighing less than 23kg on the market
Andrew Everard:I see no reason why such a combination of specifications shouldn't be possible at some indeterminate pont in the future - after all, there are already 46-47in TVs weighing less than 23kg on the market
My stand is 43 inches wide would anything bigger than 43 inches look stupid?
Only you can judge that, but it wouldn't be optimally stable, given that most 50in diagonal TVs are also around 50in wide by the time you take in the screen bezel, etc. Most sources suggest the stand should be at least as wide as the TV.
Andrew Everard:Only you can judge that, but it wouldn't be optimally stable, given that most 50in diagonal TVs are also around 50in wide by the time you take in the screen bezel, etc. Most sources suggest the stand should be at least as wide as the TV.
Wow, I better play it safe with a 40 inch then, thanks for all that.
Any future house moves will defintely take into account a big tv for the wall then.
Cheer's.
gel:
Cheer's.
I'll just warn you the upgraditus might kick in. I went from a 37 to a 50 inch and within a couple of months i wanted bigger!
I think when you buy a home cinema system it's all about compromises. Budget, Size, Brand.
