I'm very impressed with the high quality of sound produced by my new Denon PMA-600NE amplifier (bought last week from Peter Tyson), but before I can relax and enjoy it I would be most grateful for help with the following four questions, please.
1. The amp came with two "short-circuiting pin plugs" in the two phono input sockets on the rear of the amp. I've removed them in order to insert the R & L jacks from my Internet Radio in the amp (the resulting Internet radio reception through the Denon is excellent). I've stored the two "short-circuiting pin plugs" in an envelope but am curious as to what they are for. There's no explanation in the Denon's manual, only a note warning that they should never be placed in the audio output Recording sockets.
2. Over part of the grille on the top of the amp there's a rigid, clear, plastic sheet which has ventilation holes in it which are aligned perfectly with the ventilation holes of the grille (in the metal case of the top of the amp). This plastic sheet (about six inches by three inches in size) is attached to the top of the amp by four plastic clips which have been clipped to four of the holes of the grille in the metal case of the amp. It would not be easy to remove this plastic sheet, so I assume that it is not to be removed. What is the purpose of this plastic sheet, please?
3. I've used the bass, treble, and balance knobs on the front of the amp to produce the sound and balance I want, but I've been curious to hear the intended sound of the tracks I play, and the intended sound of the soundtracks of TV programmes I watch. So I've pressed the "Source Direct" button on the front of the amp while playing the TV, while playing tracks bluetoothed from my smartphone, and while playing the Internet radio. In each case I have found that switching on "Source Direct" loads about 75% of the volume onto my left speaker, so that only a little sound can be heard from the right speaker! Surely that's not what the producers of the music and programmes intended. The only difference between my left and right speaker is that the speaker cable from the amp to the left speaker is about two metres shorter than the cable from the amp to the right speaker. Does this difference in cable lengths account for the left speaker receiving greater volume?
4. I have positioned the amp on top of my DVD player in the space underneath my TV. The grilles in the two sides of the amp have plenty of space in front of them; there are two cable holes (about 2" in diameter and about 18" apart) in the back of the cabinet, directly behind the amp (so there is an air-flow at the back of the amp); and the door of the cabinet will always be open when the amp is switched on (as shown in the photo below). But when I place my hand in the space between the grille on the top of the amp and the wood of the cabinet above the amp I find that the air in that space is quite warm, due to the heat produced by the amp. Is this warmth normal? (I imagine some users may place a turntable or other equipment on top of the amp.)
