3.5mm to 3.5mm right angled jack - do they exist?
I'm looking for a 3.5mm to 3.5mm right angled jack (male to male, no cable length)
I have been looking desperately for such a device. Has anyone seen one before, do they exist?
Are you sure you don't need a 3.5mm male to female like this one?
http://www.needledoctor.com/Online-Store/Right-Angle-1-4-Male-to-Female
Or is there a way you could use a 3.5mm to rca adapter, like this:
http://www.audioadvisor.com/prodinfo.asp?number=AQMINI
If the above suggestions don't fit the bill, then ask these people to make you a custom 3.5mm to 3.5 mm plug using a very short peace of cable in between:
http://www.actionhardware.co.uk/sales/product_info.php?cPath=119_141&products_id=1029
Many thanks for your suggestions Solomon. Very helpful.
I will try making a custom plug.
