2160P HDMI Cable
I have noticed this on the Keene Electronics website.
http://www.keene.co.uk/electronics/multi.php?mycode=HDHDC1
Does anyone know if there's anything in the pipeline to make a TV capable of displaying resolutions at 2160P. If so, is there any point in buying a 1080P TV?
See Below:
HDMI Professional Range
HDMI plug to HDMI plug professional range v1.3b
certified 2160p rated
These ultra high speed HDMI cables are certified to 1.3b Category 2, meaning they are capable of 20.4 Gbps and can handle resolutions of up to 2160p!
• Resolution supports from 480p, 720p/1080i, 1080p, 1440p, WQXGA, 2160p and higher.
• Digital Audio capable of multi-channels from 5.1, 7.1, 8.1 to 13.1 channels.
• Deep Colour capable to handle (10,12 or 16-bit) Over one billion colours.
• x.v.Colour™ or xvYCC ready can support 1.8 times as many colours as existing HDTV signals.
• HDCP compliant and CEC ready.
• Capable of handling the highest speed, up to 20.4 Gbps.
Simon Lucas
84
I saw an 82in Samsung screen last week at IFA, described as 'Ultra High Def'. It's a 3840 x 2160 resolution, meaning it's 4 times the definition of Full HD.
It was displaying a loop of around 90 seconds of (extremely impressive) images. I believe that only JVC has 'UHD' cameras, and then only a couple (though that last bit could be apocryphal). Content is hard to come by.
This is technology not so much in its infancy as pre-foetal. I wouldn't let it put you off a 1080 screen, unless you're prepared to wait it out for years and years.
Has anyone reviewed this cable, as it's quite cheap at only £30?
