There are reviews for both on this site but, I wouldn't feel I was losing out with the old version. Bear in mind that headphones at this level will be very revealing of any shortcomings, in your hardware or the recordings you listen too, much more so than your Celestees or my Elegias, good though they are.I have Qudelix 5K, and Fiio M11 Plus ESS. One one of my concerns is that it is little old, 2017, and new version of headphones was released. I searched but could not find differences between 2017 and 2022 variants.
Are you happy with the Celestees, if you are, why bother buying Utopias? I wouldn't bother buying Utopias unless I could also afford to upgrade from my Pathos Converto. On the other hand, if the Utopias are in as good condition as claimed, $2000 seems like a good price. Only you can decide if they are worth it to you.I have Celestee)) but it is new for me. Just I did not want to loose opportunity to buy Utopia if it is worth to buy as it is 2017 model
On the other hand, I understood from your post that I will also need better amplifier to drive it.I am happy with Celestee. No doubt.
It just looks to me that 2.000 usd good price for mint condition Utopia. However , I could not be sure if it is worth to buy since it is 7 years old headphones.
If the Utopias are in as good condition as stated and, little used, then $2000 does seem like a good price. Only you can decide if you are happy about buying 7 year old headphones. If you are not sure, don’t do it, your Celestees are very good headphones.I am happy with Celestee. No doubt.
That is certainly my view. A few months after I bought my Elegias, I upgraded from an Audiolab M-DAC to the Pathos Converto mk2, it really brought them to life and showed what they can do.On the other hand, I understood from your post that I will also need better amplifier to drive it.
Should be easy enough to sell on if the OP doesn't like them.If the Utopias are in as good condition as stated and, little used, then $2000 does seem like a good price.
A bit late now, they were offered for sale in July, last year…they have been looked after as such expensive headphones should be, i.e. very carefully, they are probably worth it.
