- Aug 10, 2019
- 2,556
- 5
- 0
Looking here...
http://www.sightandsounduk.com/searchPage.aspx?&CatId=0&ManuId=162&s=
Thinking of buying the Audiolab 8000s int amp but was thinking of adding the Audiolab 8000p power amp onto it to give it a bit of a boost, as the A8000s can be set to be used as a pre amp. In this situation would i not be better getting the dedicated pre + power amp then....8000Q + 8000P!.. Wanted to get a pre and power amp combo this time around but most combos seem to be on the pricey side. Anyone have any experiance with this kit or reccommend others in same price range?.
