2.1 Monitor Audio Bronze Set Up
mcjwalters
76
Am looking at the idea of using my MA Bronze BR5 with a MA Bronze Centre Speaker for a 2.1 set- up.Would love a full surround set up but other half will not allow more cables running around living room as well as the rear bronzes being on the large size,wireless rears are an option if any work well with the BR5 and are smallish.
i guess the pros will say that you want every speaker to be the same brand and model type so its all working together. but i am using the br1's and the cenre and then some tdl bookshelfs and i will get slagged off but i think as long as the front 3 are the same it will sound great with movies as long as you get ok rears and they are in the right place and are at the right volumes, but i would say that with 5.1 music dvds/blu rays you can tell a little. I have heard that kef do some wireless rears that are pretty good. so i can see why they wont work well.
