Xanderzdad:
Which is likely to give the best sound quality please:
10m speaker cable or a 10m RCA stereo cable
I would go with long RCA cable. I have one 10m run from my dac/headphone next to laptop to amp on other side of room, did not notice any problems.
In some others places (few minutes of googling) people suggesting long rca versus long speaker cables. For example:
I don't think there is a simple answer to this (as always!) as I think it depends on the electrical properties of your processor/pre/power amp combination, plus the electrical load of the speakers as 'seen' by the amp. I have a Musical Fidelity Pre/Power driving a pair of Kef Speakers.
To quote from MF's literature.
" MF reccomends that long pre to power interconnects are used to allow the loudspeaker cables to be as short as possible.
The MF pre-amp has a very low output impedance and the power amp has a very high input impedance. This allows long interconnects to be used easily. This in turn allows the ideal of short loudspeaker cables to be achieved"
I suspect the differences between best case/worst case scenario's to be quite minor. I think the practicalities of cable layout and cost would influence me more!
It is based on the physical fact that the output impedance of a good preamplifier is low, the input impedance of a good amplifier is high, and hence the current is minimal. With the current being minimal, and the frequency limited to the audio band, we simply need a well screened analog interconnect. See the recent cable threads for more info on this
The situation is different with a power amplifer to loudspeaker connection. Here we have a very small output impedance of the amplifer and a veritable complex load of a loudspeaker (some much worse than others). The current is high and most amplifiers use feedback to improve their output quality. This requires a cable of low resistance, low capacitance and low inductance as well. This makes cable cooper hungry and (almost) impossible to screen. The lack of screen might affect the feedback circuitry. This combination of L, C and R is why Kimber cables are popular to remove all possible chance of any interactions (rare).
Ideally all speaker lengths should be the same. In practice they never are but I would give some thought to short L, C and R all having speaker cables the same length and short, with the rears allowed to be longer if amps are all in one place. The difference between 1m and 3m is really pretty small especially with good honest well-designed, non-tweako cables.
For really long interconnects there 'may' be benefit for balanced (XLR) connections but that is likely to be rare for our domestic installations.
A well designed amp, say a Tag will have no problem driving 10s of m of interconnect cables. Power amps, even top Brystons etc will not be able to do that with speaker cables without 'problems'. Long interconnects, short speaker cables all the time.
