I’m experiencing a HDMI issue right now, and it has come to light since buying a UHD TV due to my projector breaking down and not being able to afford to get it repaired or replaced.
At one point, I had a fairly cheap HDMI cable running from my processor at the back of the room to what was originally a 20 odd inch TV that used occasionally for the odd documentary. The length of this cable is 8-10m, I forget which. It was just a cheap one bought off Amazon, as all it had to do was transfer 720p picture (no sound needed). After about 3 years, this cable suddenly stopped working. I replaced it with another Amazon cable of similar length for about £17 - it was compatible with 1080P, UHD, ARC, 3D etc etc. Since then I’d changed the TV to a larger 39” 1080p screen. Everything was fine. A couple of months ago I changed to a 55” UHD TV. I played around with my soon to be discarded Oppo to see which looked better upscaling - the Oppo or the Sony TV. It was marginal, but I chose the Oppo to do it. I found that, randomly, the channel information would pop up on the screen, which becomes annoying when it happens quite frequently. I found that if I switched to 1080p output on the Oppo, the flashes of information stopped occurring. Live tried everything I can think of, and done many hours Googling to see if I can stop it happening, to no avail. This has never happened before - the only info flashing on screen up to this point was the Classé’s on screen display, but I’ve put a stop to that.
I’ll replace my current HDMI cable with an entry level AudioQuest at some point and see how I get on. If it continues, I guess it’ll be something to do with the Oppo (or maybe all Bluray players, if everyone else experiences it too). It’ll now have the duty of performing ARC duties though, as I’ll be using the Netflix and Amazon Prime apps from the TV, and will need to get the audio back to my processor.
