£300 upgrade - how would you spend it for me?
Littlelondoner
Hi, I am new to this forum and having read lots of opinions I am in quandary about how to improve my hi-fi system. If you can spare some time to consider how I could achieve the most improved sound from my system for an additional outlay of maximum £300, I would appreciate it.
I listen to a wide range of genres from rock and jazz to classical. I have a roughly equal amount of LPs and CDs and I am currently confined by my family for my "serious" listening to a small study room 9 x 9 feet (2.7m x 2.7m) .
My kit is:-
  • Rega Planar 3 purchased in 1986, fitted with an Ortofon Red MM cartridge 10 years ago and has had no further upgrades
  • Rega Fono A2D preamp
  • Arcam Delta 90 amplifier
  • Arcam Delta 70.3 CD player
  • Mordaunt Short MS15 speakers mounted on spiked tripod stands
I use good quality RCA and speaker cables. All the units including the turntable are in/on a floor standing spiked tripod type unit standing on wooden floorboards.
The obvious upgrade choices seem to be these:-
  • 1. Rega turntable wall bracket
  • 2. Rega 24V upgrade kit
  • 3. Rega NEO power supply
  • 4. Have the orginal Rega phono cables from turntable replaced with modern ones
Note that all of upgrades listed here are to do with the turntable. However, I am not averse to my £300 taking another direction such as better speakers or even a DAC - we have started to use streamed music into SONOS speakers in other parts of the house.
Looking forward to hear what you may suggest
My kit is:-
Welcome to the forum
You forgot the obvious replacing the stylus / cartridge. Ten years is a long life for a stylus, depending on usage.
However it sounds like you really need a wall mount for that turntable
Of you are lucky you could get this and a replacement 2M Blue stylus for your £300
Reactions: nopiano
Littlelondoner
Thanks very much - I half expected someone to suggest the turntable bracket, but was surprised that you think a blue stylus would improve the sound more than the other Rega upgrades. I haven't listened to my vinyl much in recent years so may wait a while before replacing the red stylus with a blue one. Thanks again.
Looks like most ideas have been reflected already. But if it was my kit I’d get:-
1. a new 2M Blue stylus, £139
2. used Chromecast Audio from eBay, c£50
3. one year sub to Qobuz, £129.99
I’d find the extra £20 somehow! Let us know what you decide.
