Hello!
Okay, I need some help. I desperately need to upgrade my current speaker system (which is a budget Creative 2.1 set-up, that is now hissing and crackling at me... Eww), and I definitely need some help finding the best within my budget and criteria.
The thing is, and these are really important things to bear in mind:
- My budget is an absolute maximum of £150 for the speakers.
- The speakers absolutely have to fit and work on a standard size Ikea Billy bookcase (depth 28cm). I live with the parentals in the shoe-box room, my current set-up is very space efficient but not very good on sound. I can spare enough for some medium sized bookshelf speakers, but they may have to be plush against the back of the bookcase (which I know may not be idea for sound reproduction).
- Aesthetics are important and where possible, I will favour a set-up I can get in white than a black one.
- Speakers will be primarily used for music and in pretty much near constant use. I also will use them for sound playback whilst watching films/programmes and occasionally, gaming. Primary focus is on music.
- All of my speakers I have thus far seem to last only about eighteen months to two years. I would like something a little more durable and can definitely handle being used a lot of the time, although not necessarily on full volume.
- Future-proof. I don't need them to last a lifetime, but I hope to not be living in my shoebox room for ever, and I'd like these speakers to be able to travel well and adapt to larger spaces when necessary.
[Edit: If it turns out going passive is best for the time being I'll probably just buy the Lepai TA2020, and upgrade when I can afford to do so and also when space allows as well]
If it helps, I am based around SW London, so if any locals know of any places to find good deals, that would also be excellent.
So, if you have any recommendations or suggestions or even just a site or shop that might be of any use, please send it my way. And thank you for any help in advanced. If you have any other questions, I'll be happy to answer.
