Yamaha RX V1067 vs. RX V2067
rana_kirti
59
Hi WhatHiFi Team & Fellow Members.....
See... I dont really need the superior video chip of the 2000. I'm more concerned about sound quality & sound output....
1067 is rated 105 watts
2027 is rated 130 watts.
I read somewhere that if we need to double power we need 10 times more watts. So to if 1 = 100 watts then 2 = 1000 watts.
1. So here there is a difference of only 25 watts....!!! So how much difference can 25 watts of 2067 make over 1067 as far "sound quality & sound output" is concerned....??
Which one & why...?
Thanks 🙂
As you saw on the other thread you started, rated power is almost meaningless. It depends on the speakers you are using and how much sustained current your amp can produce. PLEASE don't buy a receiver on the number of watts it might output.....it means almost nothing.
Hi rana_kirti
On performance alone the RX-V2067 is worth the extra £250 premium over the RX-V1067. The RX-V2067 has superior 'quality' of power (thanks to incorporating high speed thermal feedback power amp stage) over the RX-V1067. This partly helps RX-V2067 to offer an even deeper and tighter bass, greater scale, improved dynamics, superior resolution and a sweeter treble over the already superb RX-V1067.
As good as the RX-V1067 is there is no going back it (budget permitting) after listening to the RX-V2067.
FWIW, there is an even greater difference in performance between the RX-V3067 and RX-V2067 then between the RX-V2067 and RX-V1067.
All the best
Rick @ Musicraft
MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Come on Rick...which has the most watts????
grdunn123:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Hi grdunn123
Stop teasing me.
I am only nineteen
All the best
Rick @ Musicraft
MUSICRAFT:grdunn123:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Hi grdunn123
Stop teasing me.
I am only nineteen
All the best
Rick @ Musicraft
Then it's past your bedtime!
grdunn123:MUSICRAFT:grdunn123:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Hi grdunn123
Stop teasing me.
I am only nineteen
All the best
Rick @ Musicraft
Hi grdunn123
I wish. Bedtime is usually around 3-4am for me as there is too much to do. Anyway being nineteen i am young and full of energy.
All the best
Rick @ Musicraft
MUSICRAFT:grdunn123:MUSICRAFT:grdunn123:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Hi grdunn123
Stop teasing me.
I am only nineteen
All the best
Rick @ Musicraft
Hi grdunn123
All the best
Rick @ Musicraft
Sounds like you've got it sussed Rick!
grdunn123:MUSICRAFT:grdunn123:MUSICRAFT:grdunn123:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Hi grdunn123
Stop teasing me.
I am only nineteen
All the best
Rick @ Musicraft
Hi grdunn123
All the best
Rick @ Musicraft
Hi grdunn123
Watt sussed quality!
All the best
Rick @ Musicraft
Ronald Archiebald:
MUSICRAFT:
I am only nineteen
That explains a lot.
Hi Ronald Archiebald
Now, now be nicer
Just because i thought of this number before you
All the best
Rick @ Musicraft
MUSICRAFT:Ronald Archiebald:
MUSICRAFT:
I am only nineteen
Now, now be nicer
All the best
Rick @ Musicraft
I think Ronald thought of that number 30 years ago.....
MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Rick,
Thanks for such a great detailed reply for the differences between 1067 & 2067. It makes the difference much more clearer for me to understand. So its not just 25 watts more & a HQV Video chip... Its also a much more improved & detailed sound.
Cheers ;-)
rana_kirti:MUSICRAFT:
Hi rana_kirti
All the best
Rick @ Musicraft
Rick,
Cheers ;-)
Hi rana_kirti
Your welcome.
Yes, the RX-V2067's performance alone is worth the extra premium over the RX-V1067. Ime above all else you'll also get Yamaha's robustness and legendary reliability so you can consider either amp with the utmost confidence.
All the best
Rick @ Musicraft
grdunn123:MUSICRAFT:Ronald Archiebald:
MUSICRAFT:
I am only nineteen
Now, now be nicer
All the best
Rick @ Musicraft
Yes, sadly
MUSICRAFT:
I am only nineteen
Now, now be nicer
All the best
Rick @ Musicraft
I wish I had a time machine
Ronald Archiebald:MUSICRAFT:Ronald Archiebald:
MUSICRAFT:
I am only nineteen
Now, now be nicer
All the best
Rick @ Musicraft
Me too Ronald....
grdunn123:Ronald Archiebald:MUSICRAFT:Ronald Archiebald:
MUSICRAFT:
I am only nineteen
Now, now be nicer
All the best
Rick @ Musicraft
Me too Ronald....
At this point I'd be happy enough with a hot tub.
