MUSICRAFT:Vinny7:jokerpaulonline:
I have been looking at the Yamaha DSP-Z7, but on searching for the cheapest price i have found that i can get a Yamaha DSP-Z11 for the same price if not a bit cheaper. The only drawback is that it is an american model, I have been told it would be ok to use in the UK.
Has anyone got an american model? does it work ok on 240v or do u need to reduce the voltage?
I would still probably only use it on a 5 speaker system for now, would there still be any benfits on using this system over the Yamaha DSP-Z7? would the sound quality be better?
WARNING - As others have mentioned - stay away from US Amps that require Transformers to work.
I bought the Denon AVR-4308. Nothing but problems it has created.
1. Quality Drops (unless you have a perfect transformer - dont think there is one)
2. Transformers of that sought are generally noisy so will always create a audible hum
3. Shipping Costs & All Other Taxes WILL add up to be expensive.
4. Adding up all the costs - the difference in saving is not as much as you think...
5. Lack of Warrenty is a nightmare (had to repair my Denon 3 times so far within 18 months - and yes you have to pay for EVERYTHING)
Hi Vinny7
Good post.
All the best
Rick @ Musicraft
I calculated that shipping it from the US with taxes, P&H, step-down transformer, return shipping insurance and all that shizz adds up to about AU$5000. In Australia it lists $8000. So with a bit of discounting and bundling and free installation, the extra cost is probably worth it for peace of mind and simplicity (i.e. no pain and suffering). Plus I don't feel like I ripped of a store by demoing and not buying from them.
Hi Vinny7
Good post.
All the best
Rick @ Musicraft
