would the prime elevation speakers be a good match
markyboy156
203
hi all
i have just bought a denon x6200w amp with a roger sound labs cg24 521 package and 2 cg4 speakers to make it 7.2
which i will connect the 2 main front and centre to a emotiva xpa3 amp
i will be using blue jeans cables i will be using a panasonic ub900ebk 4k player
my question is svs have just realeased the prime elevation speakers for heights atmos would they be a great match for the roger sound labs 7.2 package would they integrate well blend well sound very good with the rest of the package i need 4 height speakers to make it 11.2 thanks
I don't think anyone can answer that question for you on this forum. RSL speakers aren't available in the UK, and SVS hasn't released those speakers here yet. You can try and see if it blends well. Check their returns policy if you're not happy.
