when wiring up speakers that have bi wire settings if im only using chord interconnects and not bi wiring do i put my cables in the top or bottom set of connections?
The general rule is you plug it into the LF terminals, but if they're not marked in anyway (and they almost certainly are) then plug it in either, see what you think and then if you really want to, swap them over to the other set and see if you can hear any difference.
Craig M.:i can recommend snipping 6 inches off the end of your speaker cables, and using it to replace the jumper bars.ÿ slightly bassier, better sound for me.
