Wireless connection to Audiolab DAC
Jul 27, 2014
Hi all,
I have an Audiolab DAC: https://www.whathifi.com/audiolab/m-dac/review
and I would like somehow to play music through it from my mobile phone (wireless or bluetooth).
Is there some adapter that I could plug into the DAC to achieve this?
Thanks!
chebby
1,253
26
19,220
Thanks!
Arcam Mini Blink
You won't even need the Audiolab.
(Plenty even cheaper but it has Arcam hi-fi 'credentials' if that is important. Well reviewed by it's amazon customers.)
Gray
I wanted a cheap wireless connection from laptop and tablet to amp for non-critical listening.
So, at £20, this was good enough for me:
https://www.amazon.co.uk/gp/product/B01CZVCYU0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
For the money, it's great (and at one time it was selling for £12.99!). It goes direct to amp (not via the M-DAC) However, it's not aptX capable, or anything special in terms of its built-in DAC. So for a closer match to your M-DAC, that Arcam Chebby has suggested is probably more like the quality you're after.
Alternatively, you could always go for a receiver with digital out, if you really wanted to use the M-DAC - though that wouldn't necessarily sound any better than the Arcam direct to amp.
chebby
1,253
26
19,220
Adrian David said:
Thanks guys,
I would still like to use the Audiolab - so I would just need a wireless receiver that has Digital coax or optical output that I could plug into the DAC.
Does the Arcam Mini Blink offer this?
Adrian
No, but not sure why you need to over-complicate matters by running two boxes rather than one. (Besides, the Audiolab is probably total ‘overkill’ for BT.)
Why didn’t you get a wireless capable DAC right from the beginning?
ChrisIRL
36
Arcam Blink is what you need. The original one, not the later mini version.
It has a coax output so you can send a digital signal to your mdac. Use a coax cable to connect to a coax input on your mdac.
chebby
1,253
26
19,220
Why use a DAC to feed another DAC? Just use the Blink on it’s own. Less clutter and a wedge of cash from selling the old one.
ChrisIRL
36
Well he did say he wishes to continue to use the mdac, perhaps for other sources? If that’s not the case I agree with you, the blink is a good enough dac on its own.
jjbomber
Pure Jongo A2. Bluetooth input and optical digital output. £20 new just about everywhere these days, reduced from £100. Unbeatable.
