I have a 1080P TV but have just ordered a 4K Blu-ray player and some 4K discs. Will these 4K discs look better than 1080P discs on a 4K blu-ray player even though it's still a 1080P TV?
You wouldn't be able to play 4k to your TV set. You can play 1080p on your 4k blu ray player but 4k disc will be a waste of money on your 1080p TV set.mannisrai said:I have a 1080P TV but have just ordered a 4K Blu-ray player and some 4K discs. Will these 4K discs look better than 1080P discs on a 4K blu-ray player even though it's still a 1080P TV?
I thought the same, but it's not true.Native_bon said:You wouldn't be able to play 4k to your TV set. You can play 1080p on your 4k blu ray player but 4k disc will be a waste of money on your 1080p TV set.mannisrai said:I have a 1080P TV but have just ordered a 4K Blu-ray player and some 4K discs. Will these 4K discs look better than 1080P discs on a 4K blu-ray player even though it's still a 1080P TV?
You must have a 4k TV set to watch a 4k signal.
bigboss said:I thought the same, but it's not true.Native_bon said:You wouldn't be able to play 4k to your TV set. You can play 1080p on your 4k blu ray player but 4k disc will be a waste of money on your 1080p TV set.mannisrai said:I have a 1080P TV but have just ordered a 4K Blu-ray player and some 4K discs. Will these 4K discs look better than 1080P discs on a 4K blu-ray player even though it's still a 1080P TV?
https://www.avforums.com/threads/4k-uhd-bluray-player-through-1080p-proj...
Not all 4K BDs have Atmos soundtracks and not all 1080p BDs don't.abacus said:The main advantage of using 4K disks for HD is if you have an Atmos/DTS-X system, as manufactures tend to only supply theses soundtracks on 4K discs.
4K when done right is great but so often let down at the moment.bigboss said:I still buy 1080p blu ray discs with Dolby Atmos. My preference in 3D over 4K.
Benedict_Arnold said:Back on subject, did you ever try plugging a VHS tape player into an old black and white TV, and when you did, did the black and white TV play colour movies in colour or black and white?
I would say the old black and white TV would play black and white but it’s so long ago now unless the VHS player had a colour in coder built inside . I also remember VHS and beta max as wellBenedict_Arnold said:Back on subject, did you ever try plugging a VHS tape player into an old black and white TV, and when you did, did the black and white TV play colour movies in colour or black and white?
