Wiim setup
haydenseymour
I'm new to all this streaming stuff and I'm old so this technology is a little ahead of me.
My setup is:
Ruark Mr1 mk2,
Ruark Sub
WIIM PRO PLUS
My questions are:
I've used the optical cable to connect Wiim to speakers.
Would I gain anything by connecting another way?
What volume should I set the Wiim at as both can be controlled separately?
If using BBC sounds via the Wiim microphone button, how do I reply when it asks me what I want to listen to (as pressing the button on the remote seems to start the process again)?
Can the Wiim control my Ruark RS1s or my Audio pro C3 in anyway?
Reactions: Revolutions
Given the specs of the dac in the WiiM pp vs the speakers, connecting via rca should give you a fair boost in quality.
No idea about voice commands, sorry.
I think that would not necessarily be true, in WHF's review I quote:
'There’s plenty of space between instruments in the airy soundstage, giving songs an expansive feel'.
I wouldn't be surprised if the optical input gives better results than the Wiim's internal DAC.
Reactions: haydenseymour
My setup is:
Ruark Mr1 mk2,
Ruark Sub
WIIM PRO PLUS
My questions are:
If you're using the optical out, then the Wiim should give you the option to disable its volume control and use it as a pure transport. I would however experiment with this - leaving its volume control between 70 and 80% and see how it sounds.
I like the option of fixing. One less thing to worry about!
" BBC sounds via the Wiim microphone button"
I've found that Alexa sometimes gets hung up on the BBC Sounds app on both WiiM and my Echo Show 8. It will go off and pull up the right screen, with channel ident and even the text for the name of the show being aired, but no audio. I've no idea why, but I've found asking her to play BBC News often gets it working again. So if, say, Radio 4 fails to play, I try BBC News instead, and if that works, Radio 4 will normally work on the next attempt.
My suspicion is that it is related to a weak WiFi signal.
I realise I have "lied" above. It is the Aux / RCA / line output level that you can adjust sensitivity; and I expect the only optical changes you can make are to fixed/variable volume, sample rate and bit depth. Apologies to anyone I've led astray.
I expect the only optical changes you can make are to sample rate and bit depth.
For clarification, the optical and coax out can also be switched between fixed and variable output to enable volume control through an external DAC that doesn't have its own volume adjustment.
I think you know that but the "only optical changes" bit above might confuse some.
My problem with the WiiM Mini is it had too much gain through optical out. I wish these devices had gain adjustment, without using volume.
It's a bit of a cludgey way to do it but do you have scope to reduce the output level by dropping all the EQ frequency levels by XdB?
