matthewpiano said:I'd recommend the Rega RP1. In my experience Rega build quality is better than Pro-Ject's, certainly at the affordable end. The Genie 3 I had could sound good, but it never felt very well made. Like wise the Debut I owned.
BigH said:matthewpiano said:I'd recommend the Rega RP1. In my experience Rega build quality is better than Pro-Ject's, certainly at the affordable end. The Genie 3 I had could sound good, but it never felt very well made. Like wise the Debut I owned.
Thats interesting because if you look at users opinions it seems the other way around with the Rega RP1 having noisy motor and hum problems, also mentioned by some of build quality down to the price.
Can I buy Rega direct from the factory as its not far from me?
peterpan said:REga RP3 or Project debut carbon exprit?
plastic penguin said:peterpan said:REga RP3 or Project debut carbon exprit?
I would spend a little extra on this http://www.ebay.co.uk/itm/Pro-Ject-Project-Xpression-III-Mk3-Turntable-/390612034737?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item5af24aa4b1
BigH said:plastic penguin said:peterpan said:REga RP3 or Project debut carbon exprit?
Whats that cartridge like?
plastic penguin said:BigH said:plastic penguin said:peterpan said:REga RP3 or Project debut carbon exprit?
Not as good as ClearAudio
Yet to hear a duff Ortofon cart. Pro-ject and ortofon seem to pair well.
BigH said:plastic penguin said:BigH said:plastic penguin said:peterpan said:REga RP3 or Project debut carbon exprit?
How does the Ortofon Alpha compare to the 2M Red?
plastic penguin said:As they are a similar price it'll boil down to which one takes your fancy. I've had numerous Ortofon carts over the past 30 years so I've nothing bad to say about them.
stevebrock said:BigH said:£3,400
scary! that is the cost of my system including cables etc!
