Which Speakers to complete my 5.1 package
Managed to get myself an ARCAM AVR250 at a bargain price and now need a set of 5.1s for movies and audio. I am looking for some small sattellites for less visual intrusion. Can anyone recommend a suitable package for max £450-500. Looking at the MS Alumni amongst others but not sure on the audio capabilities. Any advice would be welcome before I splash the cash.
Kef 2005?
The 2005.3 may be a tad over your budget, but they're worth the push apparently. If not, the now discontinued 2005.2 may still be lingering in stockrooms, so keep your eyes open for bargains.
You might also be able to find the non 'SE' version of the 3005 for somwhere near your budget.
Many thanks Chris, think the 2005.3 may be a tad expensive, but I'll keep my eyes open for the discontinued 2005.2. Alumni out of the question then? Only reviews seem to point to underproductive sub. but otherwise seem positive.
Hi bobajob,
HiSpek are doing the Kef's 2005.3 for £499.00 pick up £509.00 delivered.
Marco,
Many thanks for the tip- I'll see if I can demo them and hopefully make a decision
