Which speakers for my home cinema
Hi
After quite a mix up on buying new gear, i am now looking to buy some speakers for my system.
Which is a kuro 5090 , a denon 1910 and a sony 760 Br.
Due to restrictions on what they must look like ( the wife ) i have narrowed it down to three sets. This is not final and i would really appreciate your views and even experience's on this subject.
I know it might look like i'm buying all whf's best buys but being pretty unexperienced and also reading many reviews and forums i don't think i have gone too far wrong.
The three systems are :
Kef KHT 2005.3 £700
Kef KHT 3005 SE £1000
B&W MT-25 £950
Obiously any other speakers you would recommend would also help ( £1000 being my limit )
You are obviously going for a style speaker package and considering your budget, the B&W MT-25 fits the bill perfectly.
If you want to save some money, and haven't factored in the cost of speakers cables etc, then I would urge you to also consider the new Q Acoustics 2000 Cinema Pack at £550.00-£650.00 (depending on the finish).
These are not quite as discreet, in size terms, as the MT-25 and will require speaker stands though.
kinda
74
Hello,
Assuming that you need to stick to "style" speakers, the Tannoy Arena is well worth looking at, if your wife likes them.
They are a rival to the B&W MT-30, but whereas the MT-30 is still the price it was four years ago, the Arena has come down a bit, and also now included the subwoofer from the next set up, (Arena Highline 300).
When I demod the Arena was a clear step up from the 3005SE, (detail, musicality), and the MT-30, (better high frequencies for films and music). While not easy to define, the Arena also seemed to give a more cinematic (rather than surround) sound than the other speakers, and was also less fatiguing.
The Monitor Audio speakers are more boxey, but also worth a look, (though I've never demod them).
Hope this helps.
Thanks guys , i will have a look and try to get some demo's sorted
