Which speakers are best?
  • Start date
Deleted member 2457
B&W FPM speakers or the B&W CM9s2 speaker package? And which amp? Ta.
Deleted member 2457
bigboss said:
CM9 is way too big for your bedroom. FPM or Montior Audio Apex speakers are ideal.
Thanks BB, makes a lot of sense. Ta
Deleted member 2457
spiny norman said:
gel said:
I don't think so, but just looking at my options.
Ah right: just wondered as recent posts suggests the gel wallet is getting a bit itchy again ;-)
Nope, definitely saving at the moment - just sold my iPhone 6s too as it wasn't any better than my iPhone 4s to me. I think the Yamaha is a good choice. I have heard a Yamaha before and really liked it, and I will keep my Pioneer sc-lx81 too, but am going to wait for a bargain, and then look at next years models too.
Deleted member 2457
avole said:
You know you deserve them. Also, you'll be too broke to ever want to change again.
Deleted member 2457
buzz_lightclick said:
the CM9s are much better speakers, but would probably be too big for your room.
They don't cost much more though?
