Have a Denon Dra-F109, a pair of boston acoustics a26 on isoacoustics stands with van den hull clear water hooked up to my pc using a optical cable, i like the sound alot.
The speakers can handle all the power form my amp and the top is very pleasent to listen to, not at all this bright and intrusive top,with lots of fatigueness.
Have for a few weeks looked at new monitors for my pc so i have 3 monitors,screens, i have a shelf behind my 2 monitors,screens, thought it would be deep enough for my bostons,(tried it today) i was wrong, if i want 3 monitors on my desk i need smaller speakers.
By small i mean 4-5 inch woofer (min 155mm wide so i can use my isoacoustics 155 stands) high sensitivity 89-90db (in 8 ohm, min 87db in 4 ohm would also be okay) or more,be able to handle all the power of my amp, about 50watts in 8 ohm pr channel and enough deep bass so i don't need to have the crossover at 120-150hz on my subwoofer, very good top, as good or better then my boston a 26, really like the non bright top with no fatigueness from boston a26
Max price under 300€ for a pair
The boston acoustics A23 is to small 3.5" woofer and the price for the a25 is to high compared to what i paid for my a26.
