Which optical cable is best to connect my ps3 to my surround sound sysytem?
Which optical cable is best to connect my ps3 to my surround sound sysytem,are they all the same?
Or is the a variety in quality????
And also what cable is used to connect my laptop to my pc port in my TH-42pz85??
Gerrardasnails
295
Everyone has an argument on this. If your system is not £2000 plus, check out audiovisualonline and get one for £10-£15 (they deliver for free when you spend £10 or more). This all depends on your laptop/pc's graphics card and sound card. They all have different inputs. Some new graphics cards have hdmi (so you would then be able to use that). If you have dvi, you can get a dvi to hdmi cable. Same with soundcards, some will have coaxial, optical and analogue, others might have just analogue.
