Which one?
JP007
It looks like I will be buying this soon: http://www.lg.com/hk_en/home-theater-systems/lg-BH4030S
What I would like to know is if the speaker cables are not long enough, what cable should I buy? There are many here on Amazon, but I do not know which is the best for the LG BH4030S.
http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_12?url=search-alias%3Delectronics&field-keywords=speaker%20cable&sprefix=speaker+cabl%2Caps%2C233
Thanks!
RobinKidderminster
582
I expect this unit will use simple two wire/figure of 8 cable available at yr local diy store. Just find something of similar wire 'diameter'.
The specs say spring clips so go for slightly thicker if u have long runs and use a continuous length rather than joining cables if possible. Job done
JP007
Ok thank you. What is the wire diameter for this system? I cant see is says it in the specs.
RobinKidderminster
582
This would be ideal
http://www.diy.com/nav/fix/electrical/electrical-cable/speaker_cable/SLX-Gold-OFC-Speaker-Cable-2-x-79-Strand-20m-9686718
But any electrical store would.have similar. Or ebay/amazon etc
